Ansys Learning Forum Forums Discuss Simulation Fluids Force Calculation on a Specific Coordinate Reply To: Force Calculation on a Specific Coordinate
Then you need a surface. That can be a single facet so you can split a small section of the existing mesh to use for reporting. Have a look at mesh separate and (adaption) registers. However given pressure is force per area adjusting the values should work.Â
