Ansys Learning Forum Forums Discuss Simulation Fluids Unstable total heat transfer rate and total mass flow rate Reply To: Unstable total heat transfer rate and total mass flow rate
It's odd that you've got more VOF diffusion in the finer mesh. What you're seeing is likely some change in wetting effect, and given the significant difference in density, cp etc that'll easily give rapid jumps in values. Try running the 6M cell mesh with transient and see how it behaves.Â
