Ansys Learning Forum Forums Discuss Simulation LS Dyna Interaction between solid elements in SPG Reply To: Interaction between solid elements in SPG
Ram Gopisetti
Hi Fritz,
What is the SPG section card situation ? , what is the IDAM value here ? , have you looked into correct failure criterion of IDAM based on the Material used?
What solver you have been using ?
cheers, ramÂ
