Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › extract and graph the strain values along an area › Reply To: extract and graph the strain values along an area
Insert "Strain > Vector Principal" to see the principal directions:
Any deformed area you want to compute will need to be done in an APDL command snippet. You can communicate Mechanical with APDL by putting geometry in a named selection. Then in the APDL code, use CMSEL,S,named_selection to select those nodes.
What are you trying to plot? A strain result is a contour plot whose values change over point locations on the geometry. Area is not a point entity. Are you trying to get the area of each element and plot against the strain at the centroid of each element? Or the effective area around a node against strain reported at that node? APDL has the function ARNODE() to compute effective area around a node. Or the area of an entire face plotted against the average strain over that entire face?
