Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Import Material Properties in .txt file to ansys mechanical › Reply To: Import Material Properties in .txt file to ansys mechanical
It worked , I was checking for difference in solution results with and without command lines but there was no difference. But then I created the case files again from scratch and solved them now there is a difference in results among both cases. I also looked into solution's worksheet and found there that 10 Mat IDs are defined for the mesh. So I guess it works.Thanks for your help Mike.
Just to double confirm, could you let me know any apdl command that can be used in post processing to show the material properties of the MatID or Element ID I want to check.
