Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Calculating the Kv value of a valve › Reply To: Calculating the Kv value of a valve
January 4, 2024 at 11:43 am
Rohan Gulavani
I think you want to constraint your results i.e. dp=1 bar. I guess you have to increase pressure at inlet till you get dp =1. Remember here pressures are in bar. You have to take into pa while calculating Q and kv
