Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Faster simulation for asymmetric model & Maxwell co-simulation with Matlab › Reply To: Faster simulation for asymmetric model & Maxwell co-simulation with Matlab
Thanks for your reply~ I'm new to Maxwell so I'm a bit confused about the scenarios in which I can use a 2D model. I asked a friend and he told me that I can't use 2D since my transducer has a 3D magnetic circuit... I've attached the structure of the transducer below. In Fig. 2, the red area is the permanent magnet, and the gray area is the coil window to pick up the signal generated by the rotor rotation. The magnetic circuit is shown in the upper part.
Could you please tell me when I can use a 2D model?
Many thanks!Â
