Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to get good mesh quality › Reply To: How to get good mesh quality
Dear CFD-Friend, thank you for your valuable reply.
i)I'm dealing with a 3D case, and as you can see in the previous picture I have 5 fluid domains, two of them named as (water and air1) which have been created by using the space claim editor (Prepare ----- Volume Extract) tool. The other 3 domains are created through (Design ---- Pull) tool.
My question: Is the followed procedure right to create the fluid domains? I mean is there any difference if I used (The volume Extract tool or Pull tool) to create the fluid domains? or do I need to create the fluid domains by using (Volume Extract) tool only?
ii) It's so clear.
iii) I'll do my best.
