Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Calculation of a centrifugal pump in Fluent › Reply To: Calculation of a centrifugal pump in Fluent
December 6, 2023 at 2:05 pm
Hello Javat,
To avoid getting negative pressure , you must set the appropriate operating pressure.
The operating pressure mainly depends onÂ
Density of the fluid and mach number .Â
I am attaching the Various recommendation settings on how to accurately set the operating pressure.
For more information kindly refer the attached user guide link
8.14. Operating Pressure (ansys.com)- Detailed information about pressure is mentioned.
I hope this helps you.
Thanks,
