Ansys Learning Forum Forums Discuss Simulation General Mechanical Temperature setting of time and temperature dependent heat load Reply To: Temperature setting of time and temperature dependent heat load
Nina Schreiber
I have effectively resolved the identified issue by adding a missing comma at "hgen." Consequently, the simulation is now operational. Nevertheless, even after configuring the solver in the analysis settings for iteration, there is a persistent issue with the temperature solving process. It appears that the heat load is only considering the initial temperature. Could you offer guidance or assistance in addressing this particular concern?
