Ansys Learning Forum Forums Discuss Simulation Fluids How To Refine Mesh — Outer Area Edge Refinement Reply To: How To Refine Mesh — Outer Area Edge Refinement
SRP
Did you applied shared topology between the two surfaces? You can find more details on shared topology at user's guide: 3.8. Applying Share Topology (ansys.com)
I suggest you to create conformal mesh. A conformal mesh ensures that the nodes on both sides of the interface matches. With a non-conformal mesh, the nodes on one side of the interface does not match the nodes on the other side of the interface. The reason why conformal meshes is preferred over non-conformal meshes: with a conformal mesh there is no (or very little) interpolation at the interface which therefore reduces computational time and ensures higher accuracy of the solution.
Hope this helps you.
