Ansys Learning Forum Forums Discuss Simulation General Mechanical QUERY ON CONNECTION BETWEEN SHELL TO SOLID ELEMENT AND SHELL TO SHELL ELEMENT Reply To: QUERY ON CONNECTION BETWEEN SHELL TO SOLID ELEMENT AND SHELL TO SHELL ELEMENT
ANSYS EXPLORER
Dear Peter,
Thank you for your response.
This FE model is a prototype of Original equipment. We are trying to optimise the FEA using Solid and shell element combination as we are facing higher computational timming and memory shortages issues when we use SOLID elements fully (ONLY) . If this prototype gets sucess, then we would plan to implement the same on acutal FE model.
Regards
AE
