Ansys Learning Forum Forums Discuss Simulation General Mechanical FSUM in ANSYS Mechanical Reply To: FSUM in ANSYS Mechanical
joseph.becar
Dave,
Thank you for your response! I've somehow missed this capability for years! I will note that since it is dependent on the "Surface" Construction Geometry, it is limited to planar sections (you cannot, for example, query the summed forces and moments on a curved surface or a surface with multiple angles). This does get me through 80% of the use cases I run into on a daily basis, though, so that is great!
Joe
