Ansys Learning Forum › Forums › Discuss Simulation › Photonics › normalization in nonlinear optics › Reply To: normalization in nonlinear optics
December 4, 2023 at 9:09 pm
Chieh Tsao
Hi Dimitris,
Thanks for the reply!
I think I should attach my script. This is the script I used (Nonlinear and gain methodology – Ansys Optics)
# disable CW norm nonorm; # get poynting vector from monitor. Poynting = getresult("monitor","P"); # integrate real Pz to get power. Assume this monitor is 2D, in the XY plane # This quantity will have units of Watts/Hz^2 due to the use of the nonorm state Trans = 0.5 * integrate(real(Poynting.Pz),1:2,Poynting.x,Poynting.y); # package data into dataset T = matrixdataset("T"); # initialize dataset T.addparameter("lambda",c/Poynting.f,"f",Poynting.f); # add frequency parameter T.addattribute("T",Trans); # add transmission attribute # optionally, visualize data visualize(T);
Since I am doing nonlinear simulation, it seems that cwnorm doesn't make sense in this case.
In your script, do you get cwnorm data?
