Ansys Learning Forum Forums Discuss Simulation General Mechanical An internal solution magnitude limit was exceeded. Reply To: An internal solution magnitude limit was exceeded.
Tadeáš Salcman
Hey,
thanks fot the advice. I let it run and tried to measure Newton-Rhapson Residual Force. This is the result of the solution. It seems one of the axles in the clamp has quite high residual force. Do you think it would be solved if I change the Frictionless contact between the axle and the clamp part to a different contact type? I thought that it sould represent a pin-like movement, but I might be wrong. What do you think?
Snapshots:
