Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Boundary Conditions Shell and Tube type heat exchanger › Reply To: Boundary Conditions Shell and Tube type heat exchanger
December 4, 2023 at 10:25 am
Specify the inlet velocity based on the flow rate or the desired Reynolds number.
You can check fluent user's guide on modelling heat exchanger: 15.5. Modeling Heat Exchangers (ansys.com)
Hope this helps you.
