Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Problem when importing the STL file from solidworks into the FDTD › Reply To: Problem when importing the STL file from solidworks into the FDTD
December 4, 2023 at 7:49 am
Hi Kawshik,
Thank you for your screenshots. I would expect the two different methods to have variations. These screenshots are the R and T in the case of STL import? Do you have the R and T in the case of creating the structure in the software? If yes, how much more accurate are these?
Kind Regards,
Niki
