Ansys Learning Forum Forums Discuss Simulation Fluids How to Change the Geometry Reference Point in Ansys Aqwa? Reply To: How to Change the Geometry Reference Point in Ansys Aqwa?
Nurhalim Dwi Putra
sorry about this, I've found the answer, you just need to specify the "connection point" in the menu tree for the object you want to give a starting position. in the starting position menu, this point will be the reference point selection
