Ansys Learning Forum Forums Discuss Simulation General Mechanical Bonded contact does not work between shell body and solid body. Reply To: Bonded contact does not work between shell body and solid body.
jeon hyeon min
Thank you for your answer!
I've already changed 'shell thickness effect : ON', but result was same...
And I increased pinball radius 1mm ~ 1000mm(10 times thickness), but result was same.
Is there any way?Â
