Ansys Learning Forum Forums Discuss Simulation Fluids Airfoil pressure coefficient Reply To: Airfoil pressure coefficient
Federico
Hello Aras,
if you're doing the proposed method above after stopping the transient solution, you will get a snapshot of the pressure coefficient at the current flow time.
With Data sampling, you can get a time-averaged cp for the duration of the sampling period.
