Ansys Learning Forum › Forums › Discuss Simulation › Photonics › “Scat_ff” analysis object radiation pattern › Reply To: “Scat_ff” analysis object radiation pattern
Dear Amrita,
I think we can split the box monitor into two parts, the first part will cover the metasurface and will have five faces instead of six. The bottom monitor which is "z1" would not collect any field information and the field information recorded in the "five-faced box monitor" will be projected at 0 to 2pi angle and the same way we can place the second box monitor in the substrate to record the field contribution. Like before in this case the "z2" monitor will not be taken into account so whatever comes back to the substrate will get collected and a similar way will be projected in 2pi to 4pi angle. Both "five-faced box monitors" eventually cover all the 2D radiation patterns by passing through the dielectric interfaces. Please comment on it. If it is a valid idea can you please modify the codes? I am also trying from my side.
