Thank you for the explanation, Rob. I made a mistake about formula sqrt (C_MU_T(c, t))/ C_STRAIN_RATE_MAG, which should be 1/ C_STRAIN_RATE_MAGÂ since the mu cancelled by using and . now the result looks reasonable to me for 25 micron particle, which the Stokes number should be lower than 1.
Please Login to Report Topic
Please Login to Share Feed
Edit Discussion
You are navigating away from the AIS Discovery experience
