Ansys Learning Forum Forums Discuss Simulation Fluids Simulation results inconsistent Reply To: Simulation results inconsistent
You may want to look up iso-surfaces to plot contours on (for example) the y or x =0 plane.
If energy has an effect on reaction rate, and you're slightly off at (for example) 0.001s would you expect the result to drift significantly from the Fluent model?
