Ansys Learning Forum Forums Discuss Simulation Fluids TRANSIENT GAS TURBINE COMBUSTION Reply To: TRANSIENT GAS TURBINE COMBUSTION
Essence
Please refer to the tutorial:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/flu_tg/flu_tg_edm_flamelet_wtm.html
Although the tutorial explains the methane-air steady combustion, you can select hydrogen-air in the drop down box while choosing the mixture template.
As you have completed steady state solution, turn ON the Transient analysis. Select the appropriate Transient formulation in Methods section and select HOTR.
