Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Dynamic mesh-nan in cg definition › Reply To: Dynamic mesh-nan in cg definition
November 24, 2023 at 1:46 pm
Federico
Hello,Â
did you adjust your time step size accordingly when changing the frequency?Â
Also, mesh preview will deform the mesh, hence you will need to re-read the case to a previous state with undeformed mesh. To a Mesh Check and make sure the CG coordinates are valid before you initialize the motion.
