Ansys Learning Forum Forums Installation and Licensing Ansys Products Output of ‘mooring stiffness matrix’ from Ansys Aqwa. Reply To: Output of ‘mooring stiffness matrix’ from Ansys Aqwa.
mdti
Thank you very much for your reply. I am using Ansys Aqwa 2023 R1 and my query is now divied into two parts:
  1. Actually, I’ve got two MFK files (EQUILIBRIUM.MFK & TIMERESPONSE_EQ.MFK) under my working directory (*\dp0\AQW-1\AQW\AQ\Analysis) and the contents are not the same!
    Could you please be specific on which files I should consider?
  2. Kindly take a look at the attached (part of TIMERESPONSE_EQ.MFK) file and please let me know about whether the marked portions is the correct location for combined global mooring stiffness matrix. If it is not, kindly guide me to find the correct combined global mooring stiffness matrix.
Cheers!
