Ansys Learning Forum Forums Discuss Simulation Fluids Negative Cell Volume detected in Dynamic Mesh. Reply To: Negative Cell Volume detected in Dynamic Mesh.
Davide Parlato
Yes the plate is clamped on the left side and the fluid domain extends further through the front and back of our view so I guess that the only DM zone needed is the one I already have (system coupling set for the plate). Still, I don't get why it is not remeshing.
Furthermore I was thinking about the size of the cells; as you can see in 1st or 2nd screenshot there are some cells really small and with very stretched shape. Can they be a problem if the displacement become remarkable and for some reason Fluent is forcing a smoothing instead of remeshing? Is it possible that they degenerate?Â
