Ansys Learning Forum › Forums › Discuss Simulation › Electronics › 3ph Wound rotor induction motor maxwell 2D › Reply To: 3ph Wound rotor induction motor maxwell 2D
November 23, 2023 at 4:09 pm
Mahfoud Bouzouidja
Hello again, thank you for your response. I managed to figure it out but i still have somei issues which i can't find examples for. Such as the phase between the Voltage sources, i did 0 degrees for PhaseA, 120 for B and 240 for C and i don't know if it's correct also i have attached the circuit i have been using to creat an excitation just for the stator in an induction motor just to test it out i would like your feed back on it what am i missing to replicate the excitation from rmxprt.Â
Thanks in advance
