Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CYCLONE SEPARATOR WITH DDPM › Reply To: CYCLONE SEPARATOR WITH DDPM
November 23, 2023 at 11:41 am
With DDPM use air only for the inlet and add a surface injection to that face (Injection panel in DPM model). Depending on loading you may want to explore Rocky-Fluent coupling too.Â
As a starting point just run flow and DPM particles. Once that's stable you can make it more complicated by turning on DDPM etc. Note, that may result in needing to rerun from scratch as the Eulerian mulitphase model handles the Dense part of DDPM.Â
