Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How can a transistor be inserted into Circuit Design? › Reply To: How can a transistor be inserted into Circuit Design?
November 22, 2023 at 7:57 pm
I am confused here. You have mentioned that you are looking for three terminal BJT unlike the N-port model based on s2p format.
It would be difficult to comment on the correctness of the modification without looking at the s2p file used. You can insert the modified model in a test circuit and verify its operation before proceeding further.
Best regards,
Praneeth.
