Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to set the excitation surface of excitation coil in magnetic ring? › Reply To: How to set the excitation surface of excitation coil in magnetic ring?
November 22, 2023 at 3:24 am
Hello ,did you solve the problem? I have the same problem. I bulit the same core and coil,and I set the excitation surface in the YZ plane . Finally, i got a error "Process '3dtds' terminated abnormally. It may have run out of memory or could have been killed by the user",but I have the enougth ram ,it is 64GB.
