Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Parameterize Arrhenius factors in Fluent › Reply To: Parameterize Arrhenius factors in Fluent
November 21, 2023 at 3:05 pm
I've checked the Fluent text user interface and it looks that not all settings related to reactions are exposed in the text interface. One possible workaround would be to use a Chemkin mechanism file. You can modify the reaction kinetic data and then re-import the mechanism file using the text command:
/file/import/chemkin-mechanism
