Tonmoy
Dr. Basu,
I really appreciate your help and guidance to resolve this issue. The application of intertia force through LOAD_BODY worked like a charm and solved the problem. I also tried out the small timestep suggestion and now I can overlay LS-Dyna calculated displacement with alternatives.
Thank you again for your time and all the suggestions.
Sincerely, Tonmoy.
