Ansys Learning Forum Forums Discuss Simulation LS Dyna LS-Dyna result: displacement vs acceleration Reply To: LS-Dyna result: displacement vs acceleration
Tonmoy
Thank you Dr. Basu for your wounderful recommendations.
I have another question in this regard. The LS-Dyna computed time step uses CFL limit, right? So, it changes to smaller or larger value depending on the deformation state of my system at a specific time instance. Should I use the minimum time step to do this comparison then?
Regards, Tonmoy.
