Ansys Learning Forum Forums Discuss Simulation General Mechanical Beam probe in Harmonic response analysis Reply To: Beam probe in Harmonic response analysis
Devaiah
Hi Erik,
Per your input I was able to get the desired results. Below is the code for reference.
Also, I'm wondering, is the bolt coordinate system used to arrive at these moments and forces?  If yes, would the bolt cs be at the centre of the 2 scoped remote points which were used to define the Bolt connection?
Thanks.
