Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Beam probe in Harmonic response analysis › Reply To: Beam probe in Harmonic response analysis
November 20, 2023 at 7:46 am
Hi
You can find all commands in the apdl command reference section of the help manual.
In the script you need to adapt the set command (sets the results to look at) and the esel (not sure beam1 is defined ).
Hope this helps
Erik
