Ansys Learning Forum Forums Discuss Simulation Fluids BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES error Reply To: BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES error
Yiqing zhang
I am calculating a two-phase water vapor flow problem in an open channel, using the VOF model. The error "BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES" is accompanied by "The fl process could not be. This error occurred after I had calculated many steps. After it appeared, all the buttons on the fluent interface could not be used. After I restarted the calculation, the same error was displayed again. How to solve it? I used 2022R1BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
