Ansys Learning Forum Forums Discuss Simulation LS Dyna Error with SN curve Reply To: Error with SN curve
Yun Huang
Hello, probably there are several elements which show high stress (higher than the stress at the 1st point on the SN curve). Are you using *FATIGUE_ELOUT? Can you remove those elements (not nodes) from *DATABASE_HISTORY_SOLID (or SHELL) and try again? *FATIGUE_ELOUT only computes fatigue damage for the elements included in binout. Thanks.
