Ansys Learning Forum Forums Discuss Simulation General Mechanical Insert a heat generation rate function as a heat source in a thermal simulation Reply To: Insert a heat generation rate function as a heat source in a thermal simulation
Bond Wolf
Thank you very much for your answer! What I'm thinking of is inserting stresses and strains as initial variables in the steady state thermal analysis, and then constructing a function about the stresses and strains via APDL commands. The function results are then added to the nodes as heat generation rate loads. Is this possible?
