Ansys Learning Forum Forums Discuss Simulation Fluids different parameters in ANSYS FLUENT simulation Reply To: different parameters in ANSYS FLUENT simulation
You can use the parametric tools in Fluent, but you may find it's more time efficient to manually alter the values of interest and then compare the output. By running Fluent standalone you can launch the solver, set the values of interest, initialise & run. Save case & data. Alter the boundary condition, do NOT initialise, and iterate. Save case & data with a different name. If you set up the new Report feature you can dump images etc out each time with minimal effort.Â
