Ansys Learning Forum › Forums › Discuss Simulation › Electronics › 3ph Wound rotor induction motor maxwell 2D › Reply To: 3ph Wound rotor induction motor maxwell 2D
Hello Mahfoud,
        We can change the excitation type to external and create a external ckt (MaxCkt). It will create windings. We need to connect winding resistance and end winding leakage inductance in series with the windings. Here we can connect stator and rotor in Y (star) connection. You can follow the below steps to create external ckt.
- Change the excitation type to external for all windings.
- Right click on Excitations>External circuit>Edit external ckt. below window will open. Click on create circiut.
3. Maxwell circuit will create. Connect the circuit as per your requirement.
4. Export the circuit. steps given below.
5. Right click on Maxwell Circuit >Export Netlist. save in some folder.
6.Right click on Excitations>External circuit>Edit external ckt. Click on Import circuit Netlist and select the circuit where you saved.
7. Run the simulation in Maxwell.
Hope this explaination will help you.
Thank you,
Harinath Vudumula.
