Ansys Learning Forum Forums Discuss Simulation Fluids Induced vibrations due to turbulent flow inside a pipe Reply To: Induced vibrations due to turbulent flow inside a pipe
Federico
Hello Pablo,
is this an acoustics simulation that you are looking to do?
If you're after the vibrations/displacement of the structure itself, you will need to couple your simulation with Mechanical.
