Ansys Learning Forum Forums Discuss Simulation Fluids Transient time table velocity and simulation time Reply To: Transient time table velocity and simulation time
900s, yes, but it's 900s from when you start the run. So, if you initialise and run with no interruptions you'll be at 900s. If you initialise, run for 4500 steps, stop, then restart without initialising you'll be at 1350s.
Note, Fluent data files are snap shots of the result at that time step, so if you run for 900s without saving any data (Autosave is there for a reason) you'll not have any results for the period between starting & stopping.Â
