Ansys Learning Forum Forums Discuss Simulation Fluids Cordinates of inlet face Reply To: Cordinates of inlet face
Govindan Nagappan
You can use the location icon to get the location of a point
If a point is not available, you will have to create one using the tools under create point
If it is a circular face, you can create splits on the circle and then create a center point starting from two points
