Ansys Learning Forum Forums Discuss Simulation Preprocessing Is it possible to merge bodies when there are errors in Check Geomtry ? Reply To: Is it possible to merge bodies when there are errors in Check Geomtry ?
Aniket
It is recommended to have a clean geometry, but, if you are not able to recreate entities with errors, you may try to mesh them and use measures like defeaturing tolerance, virtual topology, etc. but if this does not work, cleanup at geometry level is recommended.
-Aniket
Forum Rules & Guidelines
