Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › surface coating › Reply To: surface coating
November 15, 2023 at 9:46 am
Hello there,
I want to simulate the polymer flow in a continuous wire coating process. In the process, a wire with a diameter of "d" enters the liquid polymer contaier (die cavity) with a constant speed of "U". After leaving the die, how can get the thickness of coating ?. Please any comment or recommndations for naming the proper softaware will be very helpful. Thanks in advance
