Ansys Learning Forum › Forums › Discuss Simulation › Fluids › VOF evaporation problem › Reply To: VOF evaporation problem
November 15, 2023 at 9:13 am
Regarding the frequency constants, I decided to estimate the value (based on the formulae in the Theory Manual) since they aren’t available in the literature as the inverse second unit. So about the evaporation constant, did you imply I have to increase the evaporation frequency (like, into the magnitudes of millions or above)?
I will try to switch to the Eulerian model (it gotta take quite a long time due to the three-phase case) and keep you updated as soon as I get any meaningful results.
Edit: Just did yet another VOF run with an evaporation frequency rate of 40 million s-1, still no evaporation occurred.Â
