Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › How to mesh a Perforated Cyclinder for Structural Analysis › Reply To: How to mesh a Perforated Cyclinder for Structural Analysis
November 13, 2023 at 2:57 pm
Govindan Nagappan
If it is uniform thickness, you can import the inner surface(as surface body) into Mechanical. Create a surface mesh. Then use Pull extrude to create the solid mesh from the surface mesh
Surface body is suppressed after creating the extruded solid mesh
Example:
Consider setting quality check to No in details of meshing if the aspect ratio is high. SInce the geometry has high aspect ratio, the resulting mesh might have that as well.
Or consider using a shell mesh and define thickness as a property
