Ansys Learning Forum Forums Discuss Simulation Fluids Turbulent viscosity for transitional SST model in ANSYS Fluent. Reply To: Turbulent viscosity for transitional SST model in ANSYS Fluent.
Bovinille Anye Cho
Hello Mark,
Thanks for your reply. I'm running on an ealier version (2022R1), my UDF is hooked into the material property, tried a few iterations and it doesn't work.
Nonetheless, I have been able to use the custom feild function and patch it into a user define memory, and then read the UDM within the UDF, it works. Thanks.
