Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Error: Unable to start Workflow Database › Reply To: Error: Unable to start Workflow Database
Install.log file >
Start Installation: Paz Eki 22 11:47:02 2023
Revision: 2023 R1
Platform specifics:
  Windows
Username of Installer: DESKTOP-UB19VCS\Hp
User Has Administrator Privileges
C:\Users\Hp\AppData\Local\Temp\ans_install_tmp8692\instcore.exe -usetempdir C:\Users\Hp\AppData\Local\Temp\ans_install_tmp8692 -launchdir F: -admin
Initial mount directory:
  F:
Installation Directory:
  C:\Program Files\ANSYS Inc
Windows x64
   Ansys, Inc. Products
     Discovery
        Discovery
        SpaceClaim
     Structural Mechanics
        Additive
        Customization Files for User Programmable Features
        Mechanical Products
        Material Calibration App
   Ansys Geometry Interfaces
     Discovery Geometry Interface
     SpaceClaim Geometry Interface
**** NOTE: There may not be enough disk space available! ****
Based on install disk space calculations, there may not be enough disk space!
 Required: 38044 MB
 Available: 26545740 MB
The user has chosen to continue anyway.
Date verification complete...No conflicts found.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You're missing required prerequisites.
Installing MS VC++ 2019 Redistributable x86
Installing MS ASP.NET Hosting Bundle 6.0.8
Installing MS Desktop Runtime 6.0.8
Everything was successfully installed.
Reading the installation media contents - please wait.
 Extraction: F:\instcore\tcl\COMMON.TGZ ...
 Extraction: F:\instcore\tcl\WINX64.TGZ ...
 Extraction: F:\license\WINX64.7z ...
 Extraction: F:\hlp\hlplic\HLPLIC.7z ...
 Extraction: F:\instutil\INSTUTIL.7z ...
 Extraction: F:\clclient\WINX64.7z ...
 Extraction: F:\subs\WINX64.7z ...
 Extraction: F:\corewb\WINX64.7z ...
 Extraction: F:\apipsrv\WINX64.7z ...
 Extraction: F:\dpf\WINX64.7z ...
 Extraction: F:\dpf\plugins_autodyn\WINX64.7z ...
 Extraction: F:\rsm\WINX64.7z ...
 Extraction: F:\icemwb\WINX64.7z ...
 Extraction: F:\sec\WINX64.7z ...
 Extraction: F:\ccm\WINX64.7z ...
 Extraction: F:\blademodeler\WINX64.7z ...
 Extraction: F:\ecadxltr\WINX64.7z ...
 Extraction: F:\common\WINX64.7z ...
 Extraction: F:\commoninstall\WINX64.7z ...
 Extraction: F:\cpythext\WINX64.7z ...
 Extraction: F:\cpythnew\WINX64.7z ...
 Extraction: F:\cpythcloudext\WINX64.7z ...
 Extraction: F:\hlp\hlpviewer\HLPVIEWER.7z ...
 Extraction: F:\ansys\WINX64.7z ...
 Extraction: F:\dpf\plugins_composites\WINX64.7z ...
 Extraction: F:\artemis\WINX64.7z ...
 Extraction: F:\spaceclm\WINX64.7z ...
 Extraction: I:\framewrk\WINX64.7z ...
 Extraction: I:\disco\WINX64.7z ...
 Extraction: I:\meshing\WINX64.7z ...
 Extraction: I:\mechsrvplg\WINX64.7z ...
 Extraction: I:\disco_overlay_resources\WINX64.7z ...
 Extraction: I:\cff\WINX64.7z ...
 Extraction: I:\fluenta\WINX64.7z ...
 Extraction: I:\fluentc\WINX64.7z ...
 Extraction: I:\fluentm\WINX64.7z ...
 Extraction: I:\fluents\WINX64.7z ...
 Extraction: I:\fluentp\WINX64.7z ...
 Extraction: I:\sgcharts\WINX64.7z ...
 Extraction: I:\addprintgeometry\WINX64.7z ...
 Extraction: I:\solver\WINX64.7z ...
 Extraction: I:\data\DATA.GZ ...
 Extraction: I:\apdl\APDL.GZ ...
 Extraction: I:\python_site_mapdl\WINX64.7z ...
 Extraction: I:\aas\WINX64.7z ...
 Extraction: I:\cfxcomon\WINX64.7z ...
 Extraction: I:\lumerical\WINX64.7z ...
 Extraction: I:\addprint\WINX64.7z ...
 Extraction: I:\addprep\WINX64.7z ...
 Extraction: I:\additive_cl\WINX64.7z ...
 Extraction: I:\distcomp\WINX64.7z ...
 Extraction: I:\shapeoptimization\WINX64.7z ...
 Extraction: I:\matcal\WINX64.7z ...
 Extraction: G:\instcore\tcl\COMMON.TGZ ...
 Extraction: G:\instcore\tcl\WINX64.TGZ ...
 Extraction: G:\instcore\tk\COMMON.TGZ ...
 Extraction: G:\instcore\tk\WINX64.TGZ ...
 Extraction: G:\configs\clientlicensing\WINX64.7z ...
 Extraction: G:\configs\ansconfigdll\WINX64.7z ...
 Extraction: G:\configs\wb\WINX64.7z ...
 Extraction: G:\addins\WINX64.7z ...
 Extraction: G:\addins\ansoft\WINX64.7z ...
 Extraction: G:\addins\matdes\WINX64.7z ...
 Extraction: G:\addincfg\wb\WINX64.7z ...
 Extraction: G:\cads\cadaisol\WINX64.7z ...
 Extraction: G:\cads\cadregistry\WINX64.7z ...
 Extraction: G:\addins\injmold\WINX64.7z ...
 Extraction: G:\addincfg\minerva\WINX64.7z ...
 Extraction: G:\pyprime\WINX64.7z ...
 Extraction: G:\syscplg\WINX64.7z ...
 Extraction: G:\addincfg\turbosys\WINX64.7z ...
 Extraction: G:\cads\acispara\WINX64.7z ...
 Extraction: G:\configs\disco\WINX64.7z ...
 Extraction: G:\cads\fusion\WINX64.7z ...
 Extraction: G:\configs\spaceclm\WINX64.7z ...
 Extraction: G:\cads\spatialiop\WINX64.7z ...
 Extraction: G:\addincfg\granta_gateway\WINX64.7z ...
 Extraction: G:\addins\granta_gateway\WINX64.7z ...
 Extraction: G:\addincfg\granta_selector\WINX64.7z ...
 Extraction: G:\addins\granta_selector\WINX64.7z ...
 Extraction: G:\fluent3ddp\WINX64.7z ...
 Extraction: G:\fwgfx\WINX64.7z ...
 Extraction: G:\configs\common\WINX64.7z ...
 Extraction: G:\configs\help\WINX64.7z ...
 Extraction: G:\tp\7zip\WINX64.7z ...
 Extraction: G:\tp\angular-nvd3\WINX64.7z ...
 Extraction: G:\tp\angular-ui-context-menu\WINX64.7z ...
 Extraction: G:\tp\angular-ui-tree\WINX64.7z ...
 Extraction: G:\tp\angularjs\WINX64.7z ...
 Extraction: G:\tp\angularjs-slider\WINX64.7z ...
 Extraction: G:\tp\angularUI\WINX64.7z ...
 Extraction: G:\tp\bootstrap\WINX64.7z ...
 Extraction: G:\tp\d3\WINX64.7z ...
 Extraction: G:\tp\ffmpeg\WINX64.7z ...
 Extraction: G:\tp\IntelCompiler\WINX64.7z ...
 Extraction: G:\tp\jquery\WINX64.7z ...
 Extraction: G:\tp\ngInfiniteScroll\WINX64.7z ...
 Extraction: G:\tp\nvd3\WINX64.7z ...
 Extraction: G:\tp\qt\WINX64.7z ...
 Extraction: G:\tp\signalr\WINX64.7z ...
 Extraction: G:\tp\hdf5\WINX64.7z ...
 Extraction: G:\tp\zlib\WINX64.7z ...
 Extraction: G:\configs\ansys\WINX64.7z ...
 Extraction: G:\addincfg\ansys\WINX64.7z ...
 Extraction: G:\addincfg\mech\WINX64.7z ...
 Extraction: G:\cads\stride\WINX64.7z ...
 Extraction: G:\cads\hoops\WINX64.7z ...
 Extraction: G:\geompara\WINX64.7z ...
 Extraction: G:\designmodeler\WINX64.7z ...
 Extraction: G:\tp\intelmkl2020.0.166\WINX64.7z ...
 Extraction: G:\tp\intelmkl2021.3.0\WINX64.7z ...
 Extraction: G:\tp\openjre\WINX64.7z ...
 Extraction: G:\configs\addprnt\WINX64.7z ...
 Extraction: G:\addincfg\matdes\WINX64.7z ...
 Extraction: G:\acp\WINX64.7z ...
 Extraction: G:\addins\acp\WINX64.7z ...
 Extraction: G:\configs\acp\WINX64.7z ...
 Extraction: G:\anscust\WINX64.7z ...
 Extraction: G:\cads\acad\WINX64.7z ...
 Extraction: G:\cads\cat5\WINX64.7z ...
 Extraction: G:\cads\datakit\WINX64.7z ...
 Extraction: G:\cads\osm\WINX64.7z ...
 Extraction: G:\geomproe\WINX64.7z ...
 Extraction: G:\cads\pe\WINX64.7z ...
 Extraction: G:\cads\ai\WINX64.7z ...
 Extraction: G:\geomunig\WINX64.7z ...
 Extraction: G:\cads\nx\WINX64.7z ...
 Extraction: G:\cads\se\WINX64.7z ...
 Extraction: G:\cads\sw\WINX64.7z ...
RSS is disabled
Performing licensing configuration via the following command...
  C:\Program Files\ANSYS Inc\Shared Files\bin\winx64\tclsh.exe C:\Program Files\ANSYS Inc\Shared Files\Licensing\licadmin\scripts\LicAdminMain.itcl -silentinstallclient -release 2023 R1 -licserverinfo 2325:1055:lisanslar.cc.itu.edu.tr -lang en-us
Licensing configuration has completed.
Creating Start Menu items for Ansys client licensing ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigSpaceClaim.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigDisco.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigCommon.exe
Running C:\Program Files\ANSYS Inc\v231\Framework\bin\Win64\Ans.DriverSetup.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigAdditiveDesktop.exe
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Configuring ACP ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigACP.exe
Configuring Help ...
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigHelp.exe
ANSYS Internet Doc has been configured.
Running C:\Program Files\ANSYS Inc\v231\commonfiles\configs\winx64\config\AnsConfigWB.exe
Running "C:\Program Files\ANSYS Inc\v231\RSM\bin\AnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for 2023 R1 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 2023 R1 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\RSM Configuration 2023 R1.lnk
Creating Start Menu Shortcut for RSM 2023 R1 Job Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\RSM Job Monitoring 2023 R1.lnk
Creating Start Menu Shortcut for RSM 2023 R1 Cluster Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\RSM Cluster Monitoring 2023 R1.lnk
Creating Start Menu Shortcut for ARC 2023 R1 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\ARC Configuration 2023 R1.lnk
Creating Start Menu Shortcut for DCG 2023 R1 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2023 R1\Remote Solve Manager\DCG Configuration 2023 R1.lnk
Created Shortcut C:\Program Files\ANSYS Inc\v231\RSM\bin\HPCServices\DCG Local Portal.lnk
Created Shortcut C:\Program Files\ANSYS Inc\v231\RSM\bin\HPCServices\DCG Local Shutdown.lnk
Running "C:\Program Files\ANSYS Inc\v231\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"
Log files is C:\Program Files\ANSYS Inc\v231\CADConfigLogs\Latest\CADConfigurationMgr.log
MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\v231\CADConfigLogs\Latest\CADConfigurationMgr.log
ErrorLogger.errorFilePath is C:\Program Files\ANSYS Inc\v231\CADConfigLogs\CADConfigurationMgr.err
Prerequisites ..... Configure Success
SC  Workbench  PlugIn ..... Configure Success
Discovery Workbench Plugin ..... Configure Success
Successfully created file associations.
Installation Complete: Paz Eki 22 14:22:43 2023
Installation Complete.Â
Thanks for choosing Ansys Products!
***IMPORTANT***
After completing this installation, you need to run the Ansys, Inc. License Manager installation on each machine designated as a license server. Â These machines may have been specified during this installation or may have been previously specified.
